Got it started, but it doesn't respond to throttle input
Old Mar 2, 2003 | 06:33 PM
Nasty_Bird_'90's Avatar
I finally got the L98 started, but when I give it some gas it doesn't respond. It keeps a constant RPM. I'm going to check the TPS voltage now if that will make a difference. Anyone know what would cause this?
Old Mar 3, 2003 | 12:36 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Definitely check the TPS. Is it setting any codes?
(did you make sure to reconnect your throttle cable? )
Old Mar 3, 2003 | 08:06 AM
lol, yeah, the cable is connected . No TPS codes either .
Old Mar 3, 2003 | 04:56 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
If you open the throttle blades and don't dump any more fuel in the car will sputter and die. Make sure the blades actually open when you hit the gas. Could be that the cable is broken internally and you're getting no opening of the blades.
Old Mar 3, 2003 | 07:18 PM
I was opening the blades by hand with the lever on the side of the throttle body.
Old Mar 3, 2003 | 08:56 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Did you ever get your injector problem fixed? I thought I read something in another post.
The obviously are firing now or it wouldn't run at all.
Do you have a scanner to verify that the ECM is seeing the TPS voltage?
Old Mar 3, 2003 | 11:09 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
so even opening the blades by hand the rpms wont increase...id say its all TPS...like said get a scanner to read tps volatge to the ecm
Old Mar 3, 2003 | 11:11 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
ok try this for ***** n giggles...reset the computer it may work
either from the battery of directly by the ecm connections
Old Mar 4, 2003 | 07:37 AM
Yeah, I got the injector situation worked out. I don't have a scanner to read the TPS, but I do have a digital multimeter. That would work for reading the voltage, right? The center wire on the TPS should read .55 or thereabouts at idle IIRC (?)
Old Mar 4, 2003 | 09:04 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Yeah, roughly .54 at idle and I think 4.0 at WOT.
Old Mar 4, 2003 | 10:43 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
Turn on ignition, but don't start the engine.
With a scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.075Volts
If out of spec, loosen the two screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, that could mean a bad TPS switch and could be a cause of stumbling and driveability problems.
After setting the correct voltage, turn off ignition switch. Remove jumpers/scanner and reconnect the TPS connector as required.
specialized
Jun 18, 2022 09:26 AM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
perZ
Aug 15, 2015 01:17 PM
