TPI Intake Manifold,rear egr port
TPI INTAKE MANIFOLD rear port EGR I am looking for an the lower manifold that has the rear EGR port. Believed they were used on the 86-87 corvette. If any one has one they are willing to sell let me know. I also have a 86 lower intake base for sale with egr port into head. cast #10068015 $50.00
Found a set of Alum. Heads didn't ya? :hail: You must have to pass emissions because If you didn't, it wouldn't matter would it?
I'm getting ready to use an 86 Vette intake on my old iron heads. Since I'm not concerned about passing emissions (1954 Chevy), I don't plan to use the EGR on my rod. Bought an ACCEL Gen VII from Arizona TPI and they told me to connect the EGR Valve to the ECM and tuck it away somewhere to keep the check engine light from coming on. Hope they know what their talking about. If it don't work out for me, I'll swap intakes with you.
If you can't find the Vette intake, sell me the heads! I'd like to put-em on my car.
Hey Car 54,
Ya, let me know if you want to swap. That would be great. You got it, i live in smoggy CA. So i need to keep those emmisions police away.... Or else, i wouldn't give a damn. If not i will keep you posted if i find the intake or not. If i don't i may go to the vortec setup. Thanks again!:hail:
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All of the aftermarket bases have that EGR port in the back. I used a TPIS one for mine:
http://para.noid.org/~thresher/image...1&dispsize=800
What part of CA are you in? Check out the SoCal forum on this message board if you're in the south.
Hey Kevin91Z:
I am in Corona, Ca.. I would like to get one of those aftermarket bases, but money is low right now for the project. So i figure i will go with a stock and just port it out. I figure that would be good for now.
Hey Car 54 thanks again!
1992rs/ss
Jan 31, 2025 05:10 PM
86IROC112
Aug 17, 2015 02:00 PM
