tryig to get at least 14.00's
Old Mar 3, 2003 | 08:58 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i have a 91 z28 (305) convertible what can i do to get at least 14's with out going in the engine at the moment
Old Mar 3, 2003 | 09:16 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
well i would imagine youre not that far off. wouldnt you already be in the 14's somewhere stock? have you run your car yet at the track?
Old Mar 3, 2003 | 10:24 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Convertible LB9? is it an A4 or M5? mileage? mods?
if u had a M5 id say 13s are easy but with an a4 its gonna be a bit tougher
Old Mar 4, 2003 | 01:40 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
What gears are you currently running?
You don't want to touch the engine? Great! Get to work on the suspension.
All of this stuff will help straight line acceleration in different ways:
-Subframe Connectors
-Lower Control Arms
-Torque Arm
-Panhard Rod
-Lowering Springs (mild)
Purchased one at a time these items are relatively cheap for the benefits provided over stock stuff and this way you can improve your ET's now, and when you're ready to hop the engine and transmission up, you'll have the suspension ready to go!
If you have 3.42's go to 3.73's. If you have 3.23's go to 3.42's. The 3.23's are too tall IMO and the 3.73's are a little gas mileage trouble. I have 3.42s and plan to stay there, but it's all your personal preference.
Old Mar 4, 2003 | 11:58 AM
Bort62's Avatar
Get a Vigilante.
Best bolt on Mod you can do for your car.
Old Mar 4, 2003 | 01:21 PM
iroc22's Avatar
It's a convertible so it will be auto (unless it's been swapped).
Should have the 2.73 rear drum which means you'll need to swap those gears out for some 3.42's.
And a second vote here for the Vigilante.
Old Mar 4, 2003 | 03:33 PM
its a 91 305 tpi auto convertible 2.73's 57,000 miles and what is the vigalante and thanks for the input so far what should it run stock anyone no
Old Mar 4, 2003 | 03:53 PM
rezinn's Avatar
Probably somewhere in the 15s. A vigilante is a brand of torque converter.
Old Mar 4, 2003 | 04:34 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
When you say that you dont want to go into the engine, does that meen that you dont want to do anything at all to the engine? Or just nothing major like heads, cam, pistons?
Brian
Old Mar 4, 2003 | 08:14 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Some budget mods will make a small difference as well.
Cut your airbox(es) - free!
Get a used throttle body foil - $ 20.00-30.00
Relocate battery to trunk - $ under 5.00
Also, it should go without saying that the car needs to be in a good state of tune. So if you haven't yet, do a major tuneup to ensure all the basics are satisfied like ignition, allignment, oil & filter, transmission fluid & filter, hoses, air filter, fuel filter, tire pressure, etc. Do a search for "tomps major tuneup" it breaks everything down in detail. Very comprehensive.
Old Mar 4, 2003 | 08:39 PM
doing the tuneup this weekend already cut the airbox and i mean nothing internal cam,roller rockers, etc.
Old Mar 5, 2003 | 01:42 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Oh well then! Get some damned heads on that thing! AFR 190s should show you some serious gains and then when you are ready to proceed with internals you got the heads to reap the rewards! If you can't afford the 190's I hear Pro Lightnings are great for the buck and also World Products Torquer heads are budget focused.
92rsvortec350
19
Feb 26, 2023 03:18 PM
IROC78
May 7, 2016 08:16 PM
Zap Racing
South Central Region
27
May 10, 2006 08:28 AM
Nightcruzer
Jan 3, 2002 08:01 PM
