Simple VE Changes -
Old Mar 9, 2003 | 10:10 PM
Bort62's Avatar
Simple VE Changes -
For those wondering exactly what and how PROM Burning works -
I Have been driving around with a low RPM High Load (tip In) Stumble Since I got the TPI on the car.
Today I decided to stop being lazy and actually see what I could do about it.
So I took a closer look at my roughly approximated(VE masterd Stocker) VE tables.
I noticed that my VE's in the approximate MAP and RPM Range were a little bit higher than they probrably should be.
So I pulled them down by a factor of 20%.
I think smooth out a few peaks and valleys in the overall curve of 90-100 KPA MAP as it progressed from 400-1600 RPM
From this :
To This:
I then took a look at the Upper RPM VE's and noticed they were pretty out of whack too.
So I just sorta smoothed them a bit combining where I knew my combo Made power and just a relativley linear transition :
To This, keep in mind the graphical representation is all relative and not to scale, so these two look drastically differant because I changed the Range of VE's
All that took me maybe 10 minutes - No Scan tool just using my best intuition as to what a fuel map **should** look like ( smooth transition no nessicary peaks in odd places )
And the result was perfect, No more tip in stumble or miss at 4800 RPM (probrably represented but that rediculous peak in the first graph)
Now obviously thats still just a rough approximation and I will need to get ahold of a WB 02 to finish it all up, but it really is that easy folks.
If your engine's not stock and you're not Burning PROM's - Your Missing out.
Old Mar 9, 2003 | 10:45 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Thats good advice. I really like TC don't you? What are your thoughts about lots of knock at 3300rpm and rising? I have been getting rid of some of it through spark and fuel adjustments, just slow moving. Maybe you or someone else with more experience with prom buring has some thoughts.
wigmobile
Feb 26, 2025 02:56 PM
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
