Timing won't advance...
Old Mar 8, 2003 | 10:01 PM
abinns's Avatar
The timing is currently set at something like 13 degrees, when we set it at stock (6 degrees) it would barely run and/or start. We disconnected the EST wire and set it perfectly, but it ran horribly. Then we noticed that as we accelerated, the timing wouldn't advance, it would either say the same, or retard a degree or two (we never confirmed that one).
Any ideas as to why the timing would not advance?
Andrew
Old Mar 9, 2003 | 03:19 PM
88TAJeff's Avatar
Car: 88 T/A
Control module perhaps?
Old Mar 9, 2003 | 04:14 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Timing won't advance...
Andrew
How are you noticing the timing is not
advancing when accelerating? ALDL Scanner?
mike
Old Mar 9, 2003 | 08:41 PM
xanax's Avatar
by the looks of the way he explained it, they were using a timing light. id say possibly your balancers ring has slipped?
Old Mar 9, 2003 | 08:52 PM
abinns's Avatar
Yeah, we were using a timing light to check/set it when we stumbled upon this. The next step I'll take is seeing if the balancer ring has slipped as you suggested.
Andrew
Old Mar 9, 2003 | 09:08 PM
Bort62's Avatar
I would like to see you checking the timing with a light while accelerating.
Could get into the Circus with an act like that.
No Code 42 During all this eh ?
Old Mar 9, 2003 | 11:43 PM
xanax's Avatar
im sure they are implying one knows the difference between accelerating engine speed and vehicle speed.
the code 42 would be useless to discuss.
Old Mar 10, 2003 | 12:18 AM
abinns's Avatar
It threw a code 42 at first, then we set the timing to 6 degrees and it hasn't come back yet.
Andrew
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
EFR2000
Aug 18, 2015 08:54 PM
ZsTransAm
Aug 11, 2015 07:30 PM
