Distributor gear
Old Mar 10, 2003 | 11:00 AM
88TAJeff's Avatar
Car: 88 T/A
Distributor gear
When installing the gear on the main shaft, does it matter which way it goes? One hole has a 'divot' below it. Do I line this up with the way the rotor points?
The reason I ask is: it appears that the way it's installed will determine the rotor's position in relation to the cam. Does it make enought difference to matter?
I hope this makes sense
Old Mar 10, 2003 | 04:11 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Shouldn't matter at all.. The dist. aligns with
the oil pump rod and cam gear for timing
and engagement, so there's no relationship
if it's on the dist. shaft 180deg one way or
the other..
mike
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beastin91rs
Oct 9, 2015 07:38 AM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
