Advice on new SLP runners please
Old Mar 11, 2003 | 11:08 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I am a little suprised at how rought the casting is, especially around the runner holes as the top and bottom. Is this normal? I guess it would be worth it to round out the holes and match them to the plenum, that wont be to hard. Matching to the base would involve taking the base off. I just got on the new accel base and I sure don't want to take it off again. I guess you could use a gastet or template with thin carboard or something on the base, then match the runners to that right? I also noticed that the top holes in the runners are slightly siamesed. I assume it would be worth it to siamese the plenum to these openings right?
Is all this rounding and matching really worth it or should I just bolt them on?
Old Mar 11, 2003 | 11:40 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Re: Advice on new SLP runners please
Match them now, otherwise you won't realize much, if any, gains from the runners. You'll want to port that base too as it's cast with the same size holes as the stock base (or pretty close anyway), just with more meat to be able to port them further than you could the stock one. Fire up the die grinder and good luck!
Old Mar 12, 2003 | 09:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Larry,
You don't need to pull the base...asssuming the work involved will be with the runners.
Use the gaskets as a template
Old Mar 12, 2003 | 09:34 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Siamese the upper plenum to the runners - other wise the siamesed upper runners are negated thier effect.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
jaridjohn
Oct 5, 2015 07:01 AM
Royal_Z
Sep 30, 2015 08:45 PM
