HP Guess after mods
Old Mar 12, 2003 | 06:02 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
HP Guess after mods
Hey all I am getting the motor put back together after the cam swap and was wanting some opinions on HP numbers. Starting with a Roller LB9 with a peanut cam. Give me some 1/4 mile ideas also
Mods.
Hooker 1 5/8 Headers and Y pipe
Dynomax 3" full cat back exhaust with no Cat
Removal of Alll A/C and Air Pump
Removal and gutting of TPI air boxes...K&N Filters
AFPR @50lb
19lb Flow matched injectors
EGR plates ground down inside the throttle body
LT4 Cam 208/210 Druation .476/.480 lift
Crane Gold Full roller rockers 1.6
TB coolant bypass
Gutted MAS
TPIS air foil
3.23 Posi rearend taken from a 1997 T/A
Disc brake conversion
Thanks for the input
Brian
Old Mar 12, 2003 | 06:21 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
13.8@100mph, 230rwhp/260rwtq
Just taking a stab at it like you said.
Old Mar 12, 2003 | 06:34 PM
kevinc's Avatar
Car: 1982 Z28
fuggeddabouddit
Old Mar 12, 2003 | 09:09 PM
Yeah thats kinda what I was shooting for, I am not looking for it to be a race car. I got my 355 Hot Cam RS for the street stomping. I was looking for good power and to keep the **** off my butt
Brian
Old Mar 13, 2003 | 03:08 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
270 fwhp
340fwtq
14.0@96
thats if you can get the car to hook up good, if not ur looking at 14.20's@92
some lca's, ported intake and heads should get you into the 13.80's
Old Mar 13, 2003 | 03:21 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That's a LOT of power adding mods.
Assuming you get it tuned right
it shouldn't have a problem getting around 250 HP peak to the ground and running bottom 14's like has been said.
You will want to do some work to the heads before you run that camshaft though. They have to be able to physically handle the the valve-lift,
plus why lift the valves so high if there's no port/bowl work at all done to the heads. Head porting yourself is a fairly cheap way to add 20-30 hp with the mods you listed... so why not.
Old Mar 13, 2003 | 03:52 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
His heads are fine for that cam... stock heads are good up to .480" of lift. As for porting them yourself, unless your really experienced at it, dont expect more than 10 hp.
Well I am not planning on pulling the heads. The lift of the LT4 cam will work with the valve guides without any clearance issues. The stock heads can take up to .500 or more. I just wanted a good strong 305 to get the car around. I have plans for a 406 when I get the time and money for this car.
Brian Felts
Old Mar 13, 2003 | 09:23 PM
Engine: peanut LB9
if ur planning on a 406 do u also lan on using those headers-1 5/8" is a lil small for 400+ci. 1 3/4.
i think that cam is a lil big for a 305 w/ no ead work or intake work
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
