IAC valve
Old Mar 18, 2003 | 11:20 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
IAC valve
After a two year battle with a Idle & Stalling problem, I finally replaced the IAC & Plug connector (both original & 16yrs old) and this cured my problem finallly. No more Low idle after restarting and stalling. One less headach. That valve was not worth taking apart and cleaning ( big time carbon build up) same for the plug connector. Thanks to the guys that gave me the P/N's to track down these parts:hail:
Old Mar 18, 2003 | 11:50 AM
Jza's Avatar
Jza
Post the part numbers and your comments so that others can benefit from your experience (especially if it comes up in a search). Returning the favor is a much more satisfying way of thanking the people here. Glad you got your problem fixed.
Old Mar 18, 2003 | 12:25 PM
DJP87Z28's Avatar
Part Numbers for the following IAC Valve Repair.
IAC valve- GM p/n 25527077 *
Four Prong Connecter Plug Only- p/n W64 at Yearone**
" " with wire attached-GM p/n 12126449 ***
* $42.58 @ GMPARTSDIRECT
**$10.30+S/H ouch! @ YEARONE
***Very exxpensive $94.03 @ Dealer & $56.00 @ GMPARTDIRECT.
Note: Go with plain plug and attach the old wires.
I hope this Info will be helpful, If you have the same problem.
Old Mar 18, 2003 | 12:27 PM
Vader's Avatar
The IAV wasn't worth taking apart and cleaning? Was the pintle damaged? Other than that or failed stepper coils, there should be no reason an IAC can't be salvaged.
Old Mar 18, 2003 | 12:30 PM
DJP87Z28's Avatar
Just old age (16yrs) and not worth the effort on the old part.
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
