Will this engine work w/ TPI??
Old Mar 22, 2003 | 06:30 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Well, minus the intake manifold for carbs, will the cam they're using work with a stock TPI setup/computer and still be emissions legal?
http://www.allchevyengines.com/350-350.htm
Old Mar 23, 2003 | 02:22 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Well honestly those are some crappy heads to put on a crate motor. I wouldn't buy it, if you do pay the $150 for the Sportsman II heads, but even those are outdated. It doesn't give you enough info to determine if the cam will work with TPI and I'm not going to look it up so you need to find all the specs on it to be sure.
Old Mar 23, 2003 | 11:56 AM
yeah...my cam knowledge is not so good. I'm still trying to decipher alot of it. But thanks for your help.
Old Mar 23, 2003 | 12:06 PM
Morley's Avatar
The first cam should be fine for TPI use but you'll have to burn a new chip. Don't believe their HP/TQ chart there, their numbers cross at the wrong place, it should be 4250 RPM where they cross.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Pac J
May 17, 2020 10:44 AM
KO1
16
Oct 15, 2015 05:00 PM
loud91rs
Oct 5, 2015 10:05 PM
Luigytico09
Oct 1, 2015 08:46 AM
