Injector Identification help please???
Old Mar 23, 2003 | 05:55 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I just accuired some injectors off a 383 stroker TPI engine. I am curious as to what these really are.. The PN# is 5235302
I thank you all for any help you can provide me with.
Thanks,
Keiran
here is a pic, if that helps??
Old Mar 23, 2003 | 06:42 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Found it! THanks anyway. 87-88 350 22#s
Old Mar 23, 2003 | 09:11 PM
STIFFLER's Avatar
hey kaz... can you find out what these ones are? 280 150 223 BOSCH injector I know that but how many pounds are they...
Old Mar 23, 2003 | 09:27 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
.....stiffler, it looks like an 85 vette, 21.5lbs/hr at 36psi with a 16 ohm resistance. Hope this helps
Old Mar 23, 2003 | 09:58 PM
STIFFLER's Avatar
thanks man... i found some info aswell.. pi$$y he told me they were 24lbs... GREAT! hosed again
Old Mar 24, 2003 | 06:31 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
.....stiffler you aren't reading close enough The injectors are 21.5 lbs/hr at 36 psi. This equates to 24.037lbs/hr at 45 psi. ...hope this makes your day better......
Old Mar 24, 2003 | 07:43 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
You seem to know your stuffff about this Razor...so. I have These said injectors. 21.4 #'s at 43.6 psi. What will I accomplish with these at 50 psi????
THanks!
Old Mar 24, 2003 | 08:46 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
5235302 ID are GM p/n 17111961 22# injectors and the only one GM sells now. At 50PSI FP you get 23.6#.
Old Mar 24, 2003 | 08:50 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Excellent! That is what I was hopeing to hear, so at 51 psi should round out to around 24#'s. I have a ECM with a jet hot performance chip already too. Bring on the HP
Thanks very much!
Keiran
Old Mar 24, 2003 | 04:02 PM
STIFFLER's Avatar
oh so they are 24lbs injectors.... sweet.. thanks for making that clear for me...
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
