head gasket for aluminum vette heads
Old Mar 25, 2003 | 07:25 PM
xanax's Avatar
is the head gasket thinner for the stock iron heads? anyone have any idea what compression would be if i used the gaskets for the iron head?
Old Mar 25, 2003 | 07:42 PM
vortech305's Avatar
Do not use Iron Head gaskets.... They have metallic rings around the gaskets that could damage the heads. I have alluminum vette heads on my TPI and got myself a set of Felpro 1010 head gaskets and love em.
Old Mar 25, 2003 | 07:43 PM
kevinc's Avatar
Car: 1982 Z28
Using head gaskets not designed for aluminum heads is a bad idea. The fire rings dig into the softer aluminum surface, a process called brinnelling.
Fel Pro makes part# 1003 and 1010 gaskets for Al heads, GM sells a part# which is thinner and has smaller bore diameter if you're looking for more compression. SCE sells solid copper head gaskets in even more variations of compressed thickness, if you don't mind using liquid sealant.
Check the listings on www.sdpc2000.com for specifics on the Fel Pro and GM pieces.
Old Mar 25, 2003 | 08:13 PM
Mark W. Winning's Avatar
I will second the 1010. Its what I have been running on my vette heads for years, without an issue.
Old Mar 26, 2003 | 09:15 AM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I'll third the 1010s. I run them on my corvette without issue. They are great and also do not leave anything on the block or heads if you pull the heads later on.
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
