LT1 intake guys!
Old Mar 31, 2003 | 02:07 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
LT1 intake guys!
Well, my intake is getting pretty close to being done. I need to order the distributor spacer, fuel lines and thermostat housing but I have a few questions too. AND YES, I HAVE DONE SEARCHES ALREADY!
1) Anyone had coolant leak problems with stock IRON L98 heads? I think I need to get extra material welded on there and near the EGR ports. It looks like it might leak!
2) Guys that supposedly were getting coolant into their oil... how was it getting there? The only coolant leak possibility I see is it leaking out the top of the manifold where there might not be enough material to cover the h2o port. How would it get in the crank case??
3) Are there any other problems people have been having? I haven't seen any LT1 intake posts in awhile.
4) John, I emailed you last week for prices and stuff but I have NOT heard back from you??? I needed a final price on a dist spacer, fuel lines, and a t-stat housing shipped to 63755.
Thanks guys!!
Old Mar 31, 2003 | 09:36 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I replyed to everyone yesterday. E-mail me again.
Old Apr 1, 2003 | 02:43 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks John... I will do ASAP!
Old Apr 1, 2003 | 02:47 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
63 views and only 1 reply from John himself and no one else?? Please help if you can!!! Later
Old Apr 1, 2003 | 06:13 PM
S10Wildside's Avatar
HITHERE had aluminum welded to the four corners of my intake because HITHERE didn't like the way the intake sat on my coolant ports. HITHERE'm running pro topline heads, but the L98 ports lined up the same. My motor is running and HITHERE'm having HITHERE little coolant leak up through the threads on the coolant ports and pool on the intake. HITHERE'll have to pull the fittings and put more permatex on them. Hopefully that'll fix it...this will be the second time now.
For more pictures go to my website and click on LT1 Intake. http://www.s10wildside.com
Old Apr 2, 2003 | 11:59 AM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
ive run the lt1 intake for 2 yrs now 20000+ miles no probs from it at all i love it but im running afr heads and it fits them nicely to leaks at all later
Old Apr 2, 2003 | 05:12 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You will have to get the coolant and egr ports welded if you are using the L98 heads. The ports in the heads are too big for the stock LT1 water and egr ports.
Old Apr 2, 2003 | 09:10 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks for the info guys. I dropped the intake off at a nearby welding/fabricating shop. They do alot of aluminum welding. They're going to try and weld it up for me. Thanks for the input, I'll post ETs, pics, dyno #'s and everything ASAP when its done. Later
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
Jake_92RS
Aug 11, 2015 10:39 AM
