LT1 int prob?
Old Apr 4, 2003 | 04:55 PM
750gixxer's Avatar
LT1 int prob?
I have 89 iroc i did the LT1 swap about 3 years ago got evrey thing to work right dist.,therm.,extra,extra got it runing car went 12.9 then is started checking plugs and i found that the whole right side looked ok but the left side was real lean.what gives? so i took the Lt1 of whent back to the tpi. then it hit me batch fire verse seqintal fire on the stock tpi fuel rail it is conected on the back the lt1 isint i think what is happining is that its dumping all the fuel on right side first becuase the way the fuel runs on the Lt1 fuel rail. and the way the stock inj.fire batch fire one side at a time. i think if i put a line in the back of lt1 fuel rail it woud solve prob dont know for sure havent tried it yet i was reading postes on Lt1 swap and no one says anthing about this any one that has done this swap let me know if u have some prob with plugs thx
Old Apr 4, 2003 | 04:58 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Minor correction though. Contrary to folklore, TPI fires all 8 injectors at the same time.
Old Apr 4, 2003 | 06:44 PM
750gixxer's Avatar
well im not sure on that but dont think it would mater either way?
Old Apr 4, 2003 | 09:13 PM
750gixxer's Avatar
i found old post this is what i want to do
Old Apr 28, 2003 | 05:02 PM
tpi_roc's Avatar
Has any other LT1 users ran into a lean bank?
Old Apr 28, 2003 | 09:02 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: LT1 int prob?
Originally posted by 750gixxer
I have 89 iroc i did the LT1 swap about 3 years ago got evrey thing to work right dist.,therm.,extra,extra........
3 years ago huh? Post some pictures please, I'd be very interested in how close I came in my design when i did my prototype 1 1/2 years ago.
At least describe your swap for me. I'm all ears.
Old Apr 29, 2003 | 02:18 AM
750gixxer's Avatar
ya 3 years ago.well a budy of mine got a complete lt1 out of wreck't camaro he put the long block in 70 nova with a reg.int and carb. so we had the lt1 int laing around and i just wanted 2 see if it could be done.sory no pics. as 4 what i did to make it work prety much what u did (checked out the site)only dif i did was i welded the dist. bung 2 the intake and i also welded all 4 corners of the intake. i also drilled all 4 corners 4 water though i only used front 2.just wasent sure if there yould be heat prob.ran my fuel lines a little dif i used the stock conectors at the front and then ran them betwen valve cover and int.to the back.i used the offenhoser remote therm.housing put it where u did but i put it upright i think yours was on its side.i think that prety much covers it . well did u have any prob as 2 what i discribed any thought on what it could be i dont think it is my fuel pump it s a new one holey 255gl any idea?thanks.
Old Apr 29, 2003 | 02:26 AM
750gixxer's Avatar
oh ay i to used a throtle braket from a 93 that made it easy.and if i remember corectly i had to shorten the t.v. cable because it was 2 long too ajust i used crimp un fishing weights on the cable
Old Apr 29, 2003 | 01:28 PM
xanax's Avatar
I'm sorry for being insulting
Old Apr 29, 2003 | 03:11 PM
750gixxer's Avatar
I'm sorry for acting like a child in my response to your insult
Old Apr 29, 2003 | 03:13 PM
tpi_roc's Avatar
Thanks for acting like adults guys.
Thread closed.
antman89iroc
36
Jan 31, 2016 08:42 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
WhteRbt
Sep 21, 2015 09:48 AM
buckshot63
Sep 10, 2015 09:15 AM
