what doyou think about this combo????
Old Apr 9, 2003 | 08:58 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i have an 1989 irocz w/ 305tpi and i want make it turn out some 13 sec slips. i'm currently running 14.70's. I'm currently inrolled in college so funds are limited and i get done in a month and a half. so i will be working full time. i hope to have these all done buy the end of the summer. the car will have a 350 once this 305 is in motor heaven. so take consideration that i'm gonna try to use as many parts as i can from this motor to a 350.
------------Stage 1-----------------------------
-Edlebrock TEs headers(320)
-Flowmaster catback(360)
-high flow cat(175)
-Holley AFPR(90)
-port plenum(25)
-March Pulleys(125)
$1300----14.35's at least
-----------stage 2------------------------------
-a set of heads-
---GM ported 60cc vette heads(1300)
---World Products 305 S/R heads(800)
-a cam-
---GM Ram Jet Cam(135) lift-.431/.451 dur-196/206 LS-109
---Comp Cam (110) lift-.444/.444 dur-201/206 LS-112
---CompuCam Cam(250) lift-.438/.452 dur-208/214 LS-112
--new valvetrain--
---SDPC roller timing chain(80)
---Federal mogul Lifters(120)
---High Energy Cams pushrods(30)
---Comp Cam 1.6 roller tipped rockers(190)
-SLP runners (300)
$????----14.00's at least
------------stage 3-----------------------
-Spohn Adjustable LCA's(200)
-Spohn Relocation Brackets(65)
-Spohn SFC's weld in (350)
-Edlebrock Strut tower brace(140)
$????----13.90's
Old Apr 9, 2003 | 09:33 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If your gonna stay with the LTR on the 350 the only thing I would change would be the heads and cam. I would use vortecs with the scoggin intake (skip slp runners) and the lpe 211 cam or somthing similar.
Old Apr 9, 2003 | 09:37 PM
Engine: peanut LB9
i do plan on staying with the LTr setu at first on the 350. and i want to use the same heads from the 305 to the 350. so thats why i'm leaning towards the ported vette heads. and about the cam. in the 350 i will mostrly be using the LT4 hot cam
Old Apr 10, 2003 | 08:57 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Use the vette heads, and LT4 cam. Do the suspension and the exhaust.
DO NOT do the underdrive pulleys. Do a <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a> on underdrive pulleys, more pain and problems than they are worth.
You could go for an intake too, and that would help out the LT4 cam. Do you need to worry about emmissions? If not, contact John Millican at www.sethirdgen.org, and get an LT1 intake for your car. More than half the price that TPIS or Lingenfelter charges for thier intakes.
Old Apr 10, 2003 | 12:14 PM
Engine: peanut LB9
i have to worry about emisiions a thats why i'm not using a stealh ram setup. i have also tought about the Lt4 cam. how much does a Lt1 setup cost???
Old Apr 10, 2003 | 12:23 PM
Engine: peanut LB9
oh and why shouldn't i use pulleys. i've done many serachs and heard many opions on them.
what i've found is
that the guys who go buy the cheap pulley are are allways replacin belts and jumpin there car.
the guys who buy the kit never really have a problem
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
