Engine runs like ****
Old Apr 12, 2003 | 04:28 PM
Uwe 1985-IROC's Avatar
Car: 1985 IROC-Z28
Engine: TPI 350
Transmission: TH700-R4
Hallo to everybody !!!
I have a problem with my 85-er IROC (305-TPI/TH700/all stock) which happens from one second to another : My car sounds like a tractor and I lost a lot of power. I checked the sparkplugs, the sparkplug wires, the ignition coil, the distributor cap, the air filter and the catalytic converter: No result. I got no SES-light, used a Scanner: Nothing unusual. Whe I shift from P to D, the engine is almost dieing.
Any solutions ???
Thanks, Uwe
Old Apr 12, 2003 | 07:00 PM
ROC-Z's Avatar
How's your fuel pressure?
My car had this problem when I first bought it a couple years back. Turned out to be the fuel pump, some sensors, and those sensor's respective wiring.
Old Apr 13, 2003 | 05:18 AM
Car: 1985 IROC-Z28
Engine: TPI 350
I have to check this out, but I have no fuel pressure gauge at home. Perhaps I can get one from a buddy. Another symptom I forgot to mention : After 10 km driving, my temperature has rised to 220 degrees although the weather here in Germany isn´t very hot in April. Therefore I supposed a problem with the ignition or perhaps a dead cylinder.
Old Apr 13, 2003 | 09:32 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I'd do a compression test first, then check fuel pressure. It sounds like one of those two things.
Old Apr 28, 2003 | 10:26 AM
Ragtop Man's Avatar
What did you do to it ... anything?
This is a super long shot ... but ...
If you took the runners off, and didn't get them back in the original place, it is possible to mirror image them the wrong way, and leave a giant gaping vacuum leak that would cause almost everything you just desribed to happen.
Also, if the engine is throwing any codes ... be sure to capture those.
B
Old Apr 28, 2003 | 11:23 AM
Car: 1985 IROC-Z28
Engine: TPI 350
Sorry, I forgot to write you the solution for my problem ( I found it after 3 days of checking everything ). I looked under the hood, it was already dark outside, and suddenly I saw a plug from an ignition-wire ( at the distributor-cap ) sparkle. I changed the plug, and everything was allright again.
Thanks for your help, guys
Uwe
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
