stock IROC e/t times
Old Apr 21, 2003 | 10:59 AM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
ok my friend just bought an 89 Iroc 5.7 tpi and he is telling every one he runs all of these crazy times and that my car runs all of theses crazy times and i was wondering if anyone has a stock IROC and what it runs he told every one last year he ran a 13.00 which is funny because he gets wasted by people with 13 second timeslips under the belt
Old Apr 21, 2003 | 12:16 PM
Desert86Roc's Avatar
So go to the track and have him prove it. IF it is stock, I doubt very much that he goes any quicker than a low 14.
Old Apr 21, 2003 | 12:39 PM
Engine: LO3 and LT1
alot of people said stock Irocs will run about a 14.50 if that is that true
Old Apr 21, 2003 | 01:00 PM
KAOSRacing's Avatar
My stock drivetrain 5.7L 88 IROC (somewhere around 120K miles at the time) ran 15.04 @ 90.49 at Houston Raceway Park on a cool November evening. It had 2.77 gear and a 27.5 inch tall tire (I went through the lights in 2nd gear). 60 foot times were 2.14 to 2.17 with a 2.21 thrown in for some reason.
With a 25.5 or 26 inch tall tire, It probably would have gone a high 14.80 to a low 14.90.
I'm the 3rd owner of the car and I know everything that's been done to it. At the time it had the TB coolant bypass, removed MAF screens, drag launch rear springs, original factory shocks and struts, original factory injectors, an AFPR set at 45 PSI, a gutted air cleaner housing, dirty Fram air filters, no AIR pump, original factory cat, and a Midas exhaust from the cat back (on the car when I bought it).
I figure the restrictive Midas system kills any mods I've made so far.
Old Apr 21, 2003 | 02:01 PM
dave89gta's Avatar
I have a 5.7 also. Not an IROC, but close. All I could muster was a 14.85 on a 1.9 60ft. Thats bone stock on street tires in perfect racing weather.
Old Apr 21, 2003 | 02:17 PM
CETATornado's Avatar
Is he saying he ran 13.00 on a stock IROC? There's no way at all that could happen...that's LS1 territory, even with a decent driver and track conditions. It would take a considerable amount of modding to get an IROC into that region...I'm calling here, but like Desert86Roc said, take him to the track...
As was said above, stock 'Rocs would be in the 14's...under perfect conditions and with an excellent driver, I'd expect one to be able to best a low 14 run.
Old Apr 21, 2003 | 02:45 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've got a nearly stock GTA (similar to IROC right?...heavier if anything). Check my sig for mods and time. If he's stock....there's very little chance he ran a 13 flat. Now if he's saying something along the lines of 13.9 or 13.85....that's believable with a factory freak car on a perfect day, tail-wind, and perfect launch.
just run him at the track...that'll settle all doubts
Old Apr 21, 2003 | 03:50 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
My Iroc is in my SIG, and the best I have managed is a 14.67 w/ a 1.88 60' - FYI the stall is only 1800 (but It's a better machined converter than stock), and the rear has 3.23's.
A stock IROC with the interior stripped, smog equipment deleted, a/c deleted, spare&jack deleted might manage a 13.89... but 13.00? Never. Where was this track he ran it at? Under the sea?
Old Apr 21, 2003 | 06:26 PM
rockfourone's Avatar
13.00
how fast is the tailwind on this downhill track?
Old Apr 22, 2003 | 03:03 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
14.5, low 14's if he really know how to drive.
Old Apr 22, 2003 | 07:06 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
LOL, you know if its stock its not running 13.00, more like low-really low 14's for an L98 G92 IROC-Z28 in great running condition. I mean come on, if he's not beating cars that are running 13's, just make sure you go to the track with him next time and watch him run his 14's because it takes mods to get a 13.00 for sure.
Old Apr 22, 2003 | 08:26 AM
87transam5.7tpi's Avatar
yes I'd say around 14.5 or so depending on conditions.
BUT.........
does he have alot of NOS stickers? we all know those add lots of power
Old Apr 22, 2003 | 10:18 PM
JerseyIrocZ's Avatar
Car: 89 Iroc
Engine: 5.7 liter (L98)
Transmission: TCI 700r4
On my 89 iroc 5.7 tpi bone stock except for exaust and k&n air filters it ran 14.94. Stock times for a 5.7 camaro is around 15.1 Sec. Your friend it lying and should own a import. As that is what all the A$$hole ricers say. Take it to the track.
As for my times now i will be running about 13.5 after heavy suspension mods,new tci trans, 3.45 rear and headers.
TAKE IT TO THE TRACK AND MAKE HIM LOOK DUMB. DON'T FORGET TO RUB IT IN THAT HE RAN HIGH 14 OR EVEN 15'S
Old Apr 23, 2003 | 12:03 PM
vwdave's Avatar
Tape it, post it, and we'll laugh at his BS'ing ***.
Old Apr 28, 2003 | 01:41 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
My 91 ran a 14.3 at 96mph at the track, bone stock!!! This guy does not run 13.00-- It is just not possible. My 14.3 is the best most had seen around here
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Thirim
Aug 9, 2015 06:19 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
