Aluminium heads?
Old Apr 17, 2003 | 12:49 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Aluminium heads?
I'm searching locally for some aluminium heads for an 87 IROC. I am basically wanting the vette heads for the L98 block. What model years for the vettes came with L98's?
Old Apr 17, 2003 | 12:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
87-91, but 88-91 had the d-port heads which are better.
But unless you just have a hard-on for aluminum, there are better options, like vortec heads.
Old Apr 17, 2003 | 02:20 PM
Car: 1987 IROC Z
I have a hard on for performance.. little else. Who has the best prices for the vortecs ?
Old Apr 17, 2003 | 04:52 PM
Jim85IROC's Avatar
They're about $400 or $450 per pair, fully assembled brand new. Used you can find them for roughly half that.
They far outflow the corvette heads. The corvette heads have a ton of potential, but unless you're familiar with them and what works best for them, you're not going to help them much, and if you pay a pro, you'll have enough invested that you could have just got Trick Flows or AFRs to start with.
Do a search for vortec heads. You'll find a wealth of information on them here.
Old Apr 17, 2003 | 07:31 PM
vwdave's Avatar
Remember that to run Vortecs, you need a special base.
Old Apr 17, 2003 | 08:29 PM
xanax's Avatar
stick a super ram base on the vortec tpi and i bet you have one hell of a monster for alot less than AFRs or trickflow heads
Old Apr 17, 2003 | 10:59 PM
CrazyHawaiian's Avatar
Car: too many ...
I agree with Jim, unless you want aluminum for the weight savings, then the Vortech Heads are probably a better choice.
But since we're on the topic of the Aluminum Vette heads, I have a question. I have a 89 L98 (MAF like your 87 L98) and I'm thinking about the Vette heads because I want to even the weight distribution on my Track Car. What other components would you recommend (cam, rockers, etc) be used with the L98 Aluminum Heads on a MAF L98? I know the compression will go up about a point and EGR will be tossed (for me anyway). Pretend you didnt want an expensive trick setup. Just some cheap, easy to install components that would compliment the aliuminum heads? I dont know what to choose. Thanks!!!
Old Apr 18, 2003 | 12:33 AM
Car: too many ...
There's a great post going on about the guideplates, pushrods, and rockers when putting these aluminum heads on a L98. Check it out:
https://www.thirdgen.org/techbb2/sho...11#post1256711
After I get that sorted out, I need to choose between 1.5 or 1.6 rr's and match them with a cam. I'm thinking either zz4, LT1, or LT4 cam. I think the LT1 cams are the cheapest, saw them for around $30 on Ebay compared to around $120 for the zz4 cams. I'm wondering what the performance difference would be. I want alot of low end torque with this motor.
Old Apr 18, 2003 | 10:20 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I see L31's rebuilt with the proper 5 angle valve job, spring and guide boss modification for sale cheap on e-gay all the time. I also see LT4 (cheap), zz4 (cheaper) and LT1 (rock bottom cheap). alot of self centering late style rockers apear on there as well.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
