how will it run with these mods
Old Apr 19, 2003 | 10:00 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
OK, I'm starting my tpi conversion, the engine is a 1982 305 LG-4, the stock cam is staying and I'm going to install 1.6 full roller rockers to get a little more valve lift, the tpi is a speed density with painless harness, I'm also going to add a set of edelbrock tubular smog headers and 3 inch catback, I have a 3.73 posi disc brake rear end, serpentine belt drive with dual electric fans are also going to be added. I also have a set of 1984 5.0 ho cylinder heads, are the LG-4 heads and these the same
do I have a good combination going here the car now has a 5 speed, it was currently a 3 speed auto with 2.73 gears and stock 145 hp. what kind of performance improvements can I expect from the car
Old Apr 20, 2003 | 08:33 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I didn't know you could get a 3rd gen with a 3-speed auto.
Old Apr 21, 2003 | 12:15 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
yes sir i have one in a 82TA, (it is in an S10 now but), it came with one and it is a nice driveshaft for guys wanting to run a 3speed
Old Apr 21, 2003 | 02:04 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I think you'll be running similar times to the Lb9s... perhaps a little slower due to the cam and heads but you're doing a good thing by getting the 1.6's, those will help. I would at least pocket port the ho heads and enlarge the valves. high 14's.
Old Apr 21, 2003 | 10:50 AM
R.O.B.'s Avatar
With your stock cam, 3.73 gears will be too much. May be slightly quicker 0-60, but 1/4 mile will be slower. Try 3.42 gears instead.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
NWAsonoma
Aug 18, 2015 05:45 PM
matthew911
Aug 12, 2015 09:38 AM
