LB9 (205hp) vs. LB9 (230hp)
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
The 205hp one had what we call the "peanut cam". It was a very small cam that came in the automatic 305 TPI's.
The 230hp one had a larger cam and came in 5 speeds only. I beleive the cam is the same as what the L98's had.
Car: 89 Formula
Transmission: TH 700R4
I'll back that up--cam was the same for 91-92.
Dual cats and probably smaller pipes.
Curiously the redline in an auto car stayed at 5000rpm
Car: 04 GTO
Transmission: M12 T56
The first poster is wrong. All SD 305s have the same cam. This has been proven by inspection (i.e. cams measured in engine, engines dissassembled and cam #s checked) as well as in official GM service parts literature, as well as by inference through performance and how well a 205hp LB9 reacts to mods compared to the MAF peanut cam cars.
The only difference between 90-92 205hp vs. 230hp LB9s was the exhaust only. The 230hp cars came with bigger exhaust manifolds and dual cats compare to TBI manifolds and a single 2.25" cat for the 205hp version.
I picked up 3 tenths and 2.5 mph just from switching from my stock exhaust to L98 manifolds and dual cats, and that was still with 2.73s. So there's an application of the idea that the exhaust is 25hp.
Doh
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I've got the peanut cam I think. As I have always stated before my car runs abit stronger than a 305 car usually runs. I have no time slips to prove that. I've occasionally raced other cars that I shouldn't have been able to beat quite so easily. And come out on top.
I would ditch that peanut cam but I consider it a waste of time and money simply because I am going to skip that and build another engine. 383 most likely.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The LB9 in '85 I believe was best of the "305" engines with an automatic transmission. It did not have the peanut cam in it. The cam was changed in '86. In 87 they put the good cam back into the LB9 5speed and the L98 engines. So when you see people talking bad about 305's, it's probably not an '85.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
as ed said all sd cars got the l98 cam..
freeman...id race any 85 with my 91 t-5...
of course i blew the lb9 up lol...
Car: 1985 Iroc-Z
