Z28 Stock Times
Them are actual times......Only thing I have done is exhaust work, Don't the 350 TPI's run low to mid 14's stock?? I know Ford Tempo's that can do 15's, That 15 flat time is close to my Cavalier's time
Car: 1990 Iroc-Z
My car is my signature. My most recent best:
14.51 w/ a 1.99 60' @ 93.7mph.
Keep in mind, the 120,000 mile L98 is likely missing some compression... and the Las Vegas Motor Speedway sits 2,200ft above sea level.
NHRA correction shows the car running 14.2's@sea level.
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
What kind of exhaust work? Mine went from 15@89 MPH to 14.6@96 MPH with exhaust work!!!
The stock exhaust is quite restrictive...my car is an '89 Full load GTA so it will be slowest of the fbodies....
I also think the 91-92s are a little quicker than the earlier cars...less restrictive intact without MAF sensor?
Either way your car is running some good times...with a torque convertor, suspension work and sticky tires you are deep into the 13s!!!
