HEI on TPI
Old May 4, 2003 | 09:27 PM
88_RS_2.8's Avatar
HEI on TPI
Hi i have an 85' Z28, w/ TPI 305. Now from factory it comes w/ an HEI but its computer controlled. I have a brand new Mallory HEI, non computer controlled w/ vacuum advance. Now can i put that Mallory distributor in? Will it mess w/ the computer. Thanks in advance.
Paul
Old May 5, 2003 | 03:10 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
well yeah it should cuz all the ingition and timing et etc is all computer controlled so ur best off with stock style dist. or else ull have to change other stuff with ur computer i would think
Old May 5, 2003 | 06:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you will get an EST (Electronic Spark Timing) code 42. i have bypassed mine using the holley annihilator ignition system. now this in itself will cause only the check engine light to come on. all else will still work. the mallory distributor is mechanical and vacuum advance. so now you can make your own timing curve. been over a year like this on mine.
fbirdroller
Sep 2, 2015 10:27 PM
theurge
Aug 21, 2015 12:46 PM
stalkier
Aug 21, 2015 01:54 AM
midias
Aug 15, 2015 05:07 PM
Sanjay
Aug 12, 2015 03:41 PM
