Question for those with Big Cams
Old May 4, 2003 | 09:54 PM
ragtop88's Avatar
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
Just got done installing a hydraulic roller 236/242, 114* into my short stroke 379 and was wondering what kind of vacuum signal at idle some of you folks are seeing. Haven't pulled it out of the garage yet, just got it idling, set timing, minimum idle, etc... I'm getting about 10 inHg at idle. This was an express elevator up from my previous cam so lots of tuning to do by next saturdays race. TIA
Old May 4, 2003 | 11:01 PM
Ragtop89's Avatar
Which cam did you pull out?
BTW, I'll be seeing you next Saturday in Darlington.
Can't wait to see your car!
Old May 4, 2003 | 11:04 PM
ragtop88's Avatar
Transmission: m6
It was a flat tappet Comp Cams grind....12-404-4 I tihnk it was. 222/226 .464/.464 114* lsa. Yeah I should be there assuming nothing happens with tuning the car this weekend and getting a couple little things fixed up. See ya then.
Old May 6, 2003 | 09:24 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
8-12 is about normal, I get around 9-10 and a friend with the 236-242 was getting 10-11.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
