used injectors = blown motor?
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I need new injectors. im considering LT1 injectors or used SVO injectors.
My friend says that if one of them is bad or clogged i WILL blow my motor. does that sound right? what are the chanced of an injector blowing a motor?
Re: used injectors = blown motor?
Helpful reply deleted...I hate it when people cross-post the same question in multiple forums.
Transmission: 4l80e
Axle/Gears: 3.512
gee thanks.
i just wanted responses from more than 1 group of people. this is the first time in over 1000 posts I ever did this, and its because its URGENT information i need. How do i know whether to put this in a place where everyone has injectors or everyone has injector problems? I cannot afford to wait a week to see if anyone answers the post on one board.
Car: 89 IrocZ
Engine: L98-ish
If one or more injectors were fully or partially clogged, you run the risk of running those particular cylinders too lean...most likely you'd hear the "ping", but in a worst case scenario, you wouldn;t...could cause the piston to begin to disenigrate..etc...which could lead to a 'blown" engine.
Best bet if you're concerned about used injectors is to send them for cleaning and flow matching...but then you need to weigh the cost vs. new ones.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
