What happens when this is removed?
Old May 5, 2003 | 06:45 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I am wanting to remove the bottom part of the throttle body where the IAC is connected...what happens when I take the screws out? is a bunch of springs and stuff going to come flying out making it hard to put back together?
I already took the IAC out, can I clean all the gunk thats on it?
Old May 5, 2003 | 07:32 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
nothing in there just 2 passages one for air and one for water,be careful removing the screws ive seen them break off.
Old May 5, 2003 | 08:11 PM
OMINOUS_87's Avatar
Easy enough to remove, nothing freaky will happen. Clean it up and get all the coolant scale off. When I reinstalled mine I took a cutoff wheel and cut the "nipples" off where the coolant flows through, kinda cleans up the appearance. If you do or dont cut the "nipples" off be sure to bypass it anyway, there really isnt any need to run hot coolant through the TB.
Old May 5, 2003 | 08:32 PM
COOL! thanks for the answer...
I already had it bypassed...cutting off the nipples sounds like a good idea to clean it up around there.
I had my throttle body painted black and i stripped all the black paint off and Im going to take it to a guy and ask him if he can polish it for me, if thats do-able....or I would try and have it powdere coated but the part that the throttle cables go on has plastic and will melt...I see no way of getting that off...
Old May 5, 2003 | 11:54 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
ram air boxes
Wishmaster, do you have any pictures of your sealed ram air boxes and did it make any difference in how your car performed?
Old May 6, 2003 | 10:10 PM
rockind78's Avatar
Be very careful indeed. I spent a good deal of time fixing one with 3 broken off screws. Its fixable (well, mine was, but I guess that kinda depends on where they break), but boy they were a pain.
Old May 6, 2003 | 11:57 PM
383 rocket bird's Avatar
When i took mine apart to clean it like three of three screws broke off. I got stainless steel screws to replace them and make sure to use anti seize compound.
Steel +aluminum threads=never seize
Old May 7, 2003 | 12:12 AM
rezinn's Avatar
Half of mine broke off, as did the gasket. I couldn't find a replacement so I just repaired it. I also cut off the nipples and ground them down, and put stainless screws that I got at the hardware store in place of the old ones.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
