Injectors.....and why they go bad.
Old May 11, 2003 | 10:52 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Not so much talking about clogged injectors or bad gas. What is it that will make an injector over time go bad beyond repair and why?
Old May 11, 2003 | 01:39 PM
Morley's Avatar
Re: Injectors.....and why they go bad.
Like anything mechanical and or electrical, they just plain wear out. You have a solinoid that energizes and deenergizes millions of times over it's life which moves the pintle up and down in the housing. Movement=friction=wear=breakage
Old May 11, 2003 | 09:52 PM
chazman's Avatar
Axle/Gears: BW 3.45
I wonder if a clogged or even slightly "dirty" injector would cause greater stress on it's solenoid, causing that solenoid to fail sooner?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
armybyrd
Oct 24, 2015 06:59 AM
racereese
Oct 3, 2015 03:46 PM
mcbitchman
Sep 29, 2015 12:32 AM
HikoriYami
Sep 21, 2015 07:11 PM
