new guy ?(problem)
Old May 12, 2003 | 02:16 PM
kustom71's Avatar
new guy ?(problem)
hey how you doin!
great site helped me out alot even before i joined.
OK heres the problem:
I got a BBK adj reg. for free gor my 89 tpi 5.7
It is a low milage motor an old man had taken care of
now i put new gaskets on and cleaned and painted a few things
I install new o-rings for fuel rail and this regulator
when i goto put the plenum back on it wont fit the nut on the regulator is hitting it right between the vacuum ports.
Im lost at what to do i could put the old one back on but can i be the only one this every happen to
thanx for any help!!
Old May 12, 2003 | 02:37 PM
BTS88IROC's Avatar
Is the screw on the afpr sticking out alot? Maybe you just need to screw it in some more, if that doesn't help you could also grind a little on the bottom of the plenum.
Old May 12, 2003 | 04:03 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Welcome to the boards!
The problem your having is pretty common. You can try one of 2 things.
1-Screw in the nut until you have enough clearance to put the plenum back on. Start the car and check the fuel pressure... If its around where you want it, or lower, then your good to go.
2- With the screw as high as it can go, if you have too much fuel ressure, then your going to have to cut the screw down some. DO NOT CUT INTO THE PLENUM. The plenum is not very thick so theres no point in doing that.
Good luck!
Old May 12, 2003 | 05:00 PM
smithtc's Avatar
LOL...
I cut into plenum about a 1/2" to make clearance for AFPR.
No problems.
Old May 12, 2003 | 06:09 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I too had to grind a slot into my plenum to make the AFRP screw fit. I only had to dimple it, not hog on it.
Don't you love buying parts made for a specfic application that DON'T fit?!? Yeah, me neither...
Old May 13, 2003 | 04:14 PM
kustom71's Avatar
thanks ill try it 2night but one last thing is screw all the way in boosting pressure or all the way out boosting pressure?
sorry bought the stupid ? but im not sure how all this works yet!
thanx
Old May 13, 2003 | 04:28 PM
BTS88IROC's Avatar
As you turn the bolt in the pressure will raise, out the pressure will lower.
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
86IROC112
Apr 9, 2016 10:20 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Street Lethal
Aug 14, 2015 08:25 PM
