lift beyond .375 pointless?
Old May 14, 2003 | 11:44 PM
MinionII's Avatar
I'm sorry for my ignorance, but I've read a few threads stating that the stock TPI heads all crap out at around .375 lift. What is it that causes this stall?
I should do a search, but what are typical flow numbers for the TPI heads?
Old May 15, 2003 | 02:31 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Along with what you have asked I would also like to know if putting different rocker with a higher lift would have much of an affect.
Old May 15, 2003 | 02:36 AM
MinionII's Avatar
obviousely no expert....but if the .375 lift limit is the limit, the tiny change to the 'ramp rate' AT the valve would net hardly any power at all.
I think a cam swap based on duration is the way to go....
but what part of the design causes this stall at such low lift?
Old May 15, 2003 | 03:11 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
If the head crap out at .375 lift why does the '85 305 have .415 lift. I have very little knowledge of cams and heads.
Old May 15, 2003 | 12:40 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Not sure about the iron heads, but the Corvette heads flow fine to .500". They defintely do not stop at .375". Flow at .400" is 26 CFM more than .300". (160 to 186)
Old May 15, 2003 | 12:44 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
iron tpi heads will not tolerate more than .470"-.480" of lift without the valve hitting the guide. not a good thing.
Old May 16, 2003 | 09:51 PM
REDZ28's Avatar
I put a zz4 cam in my 91 z28 350 and it has .510 lift on the exhaust side and I didnt have any problems.
Old May 17, 2003 | 12:27 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
What are we talking about?
Where the most CFM occures at what lift on the head?
Or how much lift the cam can have before problems with the head?
I've never heard a 350 TPI head peaking at .375 lift in terms of airflow.
Did you have your heads flowed?
Old May 18, 2003 | 02:45 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Whoever told you that a stock iron head doesn't flow well over .375 is full of crap. Period.
And the valve doesn't hit the gide. It never does. Unless your vailtrain geometry is screwed up and the rocker is pulling or pushing the valve stem up against the gide. The retainers hit the gide if your trying to run a lot of lif on a stock head.
Old May 18, 2003 | 03:03 PM
Car: 1988 IROC-Z
that's what i meant. oops.
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Jorlain
Oct 8, 2015 01:57 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
