Part numbers for PCV hose/routing
Old May 15, 2003 | 09:46 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have a breather on my valve cover instead of the air supply from the thottle body. I can't find my original hose, so I've got to buy a new one. The dealer has separate part numbers for 85-87 and 88-up. Anybody know what the difference is? I looked over the hose on my 88 GTA and see no reason why it won't work on my 85. The 85 seems to be multiple parts all put together. I don't recall what the 88 looked like.
Anyway, since there was some serious confusion with the dealer (what else is new) I just want to bring the part numbers to them. I need the widget that goes into the valve cover, and the hose that goes over to the throttle body. Anybody have these part numbers?
EDIT: If anybody is wondering why this is posted in the TPI forum, it's because this hose is specific to the TPI cars, so I figured I had a better shot at getting the right part number.
Old May 15, 2003 | 01:41 PM
383 rocket bird's Avatar
Not sure about your question, but I was wondering why you are going from the breather back to the TB breather. This seems to put oily air into the throttle body. Not criticizing just curious for discussion's sake. -John
Old May 15, 2003 | 02:39 PM
Jim85IROC's Avatar
I'm doing it because without it you get a vacuum leak which causes the car to idle like a piece of crap.
There shouldn't be any oil getting back to the throttle body if the PCV valve is doing its job. The air is going to go from the throttle body TO the valve cover, not the other way around.
Does anybody know these part numbers? The diagram from the dealer sucks, and he's of no help at all. I need to know what parts I have to order.
Old May 15, 2003 | 03:47 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The part # for the 85-87 is 14087409 & is discontinued. The 88-89 # is 10105290 & can still be ordered. It appears to be routed the same, according to the GM catalog.
Old May 15, 2003 | 08:07 PM
Jim85IROC's Avatar
is that the part number for the actual tube? Do you have the p/n for the piece that sticks into the valve cover by any chance? Thanks.
Old May 15, 2003 | 08:24 PM
Ricktpi's Avatar
Iwill check tomorrow at work.
Old May 16, 2003 | 07:33 AM
Ricktpi's Avatar
Look at #s 57 & 59. They are for 1989 models.
Old May 16, 2003 | 09:08 AM
Jim85IROC's Avatar
Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
