removing throttle body
Old May 16, 2003 | 12:09 PM
lostangel's Avatar
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
do you have to drain the coolant first? i cant remember if the back of the throttle body is open or not. i just need to remove my IAC for cleaning but I was hoping not to take EVERYthing apart to do it.
Old May 16, 2003 | 07:24 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Not really. There will be a little coolant in two of the hoses attached but the back side is not open to any coolant passages.
Old May 16, 2003 | 07:35 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
You don't need to remove your TB to take the IAC motor out. Just disconnect the wire connector and wrench it off... Clean it up and put it back... Depending on the cars milage I would get a newone. If you have more then say around 120,000 miles I would replace it.
Old May 16, 2003 | 11:22 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
well if your going to clean replace your IAC why not clean the TB out?...
4 10mm bolts hold it on, theres a vacuum line hooked to the bottom..
take off the IAC housing on the bottom and clean that out and behind the TB blades and the passeges you see with TB cleaner..
put the IAC housing back on, hook up the vaccum line on the bottom, reset your IAC and TPS, and enjoy another 70,000 miles of problem free TB operation
an hour tops
800 posts!!...wooohoo!!
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
