Any tips on changing the oxygen sensor?
Subscribe
May 18, 2003 | 02:59 PM
I just got a new oxygen sensor and I'm about to replace it. Are there any tips? I read the book and it looks pretty straight forward. Or is this one of those things that's a PITA to get at and turns into an hour long ordeal for one simple thing?
Reply 0
May 18, 2003 | 03:01 PM
Soak it with penetrating oil for a few days,and use a special tool to remove it,and you'll be fine!
Reply 0
May 18, 2003 | 03:24 PM
There's a special tool to remove it?
Reply 0
May 18, 2003 | 03:41 PM
Hey,
They make a special socket for the O2 sensor. It's basically a socket with most of one side missing for the wire to go through. You could probably get away with a wrench though. I'd suggest not trying this with the exhaust hot :-)
David
Reply 0
May 18, 2003 | 06:33 PM
I just used a wrench. However, the wire they provide with the o2 sensor is just long enough to reach your connector. Don't give up on it...it will reach.
Reply 0
May 18, 2003 | 09:11 PM
I don't like the special oxygen sensor socket. It's weak and can slip. If I can't get it out with a wrench, I cut the wire and use a regular socket. A wrench will get the new one tight enough.
Reply 0
May 18, 2003 | 09:33 PM
My car is such a b!tch.. I didn't even get it off, so I decided I'll do it later this week when I get the right socket. Now my car runs weird... it was almost dying for awhile but now it's smoothed out some... i didn't even get the stupid thing of, hell, it didn't even move. My car hates when I mess with it, even when I have good intentions...
Reply 0
May 18, 2003 | 09:59 PM
the best thing i can say is get the exhaust hot!!..itll be about 1000 times easier to get out..
wear some gloves to protect your hand from heat and burns...
Reply 0
Subscribe
