Electronically limited at 2000 RPM?
Old May 19, 2003 | 02:44 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Previously I had another post named "10 minutes of performance" in which I believe that fuel was being cut from my vehicle. I am still having the same problem,
(87 IROC, 350 TPI L98)
1. my vehicle will run fine for about 5 - 10 minutes
2. It will then give out and drop below 3000 RPM and from their refuse to rev past 2000 RPM. When it kicks out, it doesnt sputter as though it is out of fuel, it actually torque brakes as though I had just downshifted too high (mind you this is an automatic).
When I shut the car down for a few minutes and restart it, the problem is resolved. Here is what has been replaced already.
1. Fuel filter (in vain)
2. O2 sensor
I have an ADS superchip that I attempted to install right after the fuel filter replacement. Upon installing the chip, I could not get the camaro to start. I replaced it with the original chip and it started up again however, this is also when these problems started as well. For a while I thought the problem was this Redline injector cleaner I put in, so I ran a few tanks of gas through it but still nothing.
I am starting to think that I have a bad chip now. (I have a new MAF on the way just so that I can eliminate the possibility that it is the problem) Anyone have any ideas or had a similar experience to share?
Old May 19, 2003 | 04:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Any codes?
To eliminate the MAF, unplug the electrical connection to it.
Old May 19, 2003 | 06:54 PM
Car: 1987 IROC Z
Unfortunately, I don't know yet, going to replace ALL of my fuses tonight because many of the indicators are not working...
Old May 20, 2003 | 07:48 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I had a similar problem with my 89 formula, It would not rev over 2000 rpm at times, ended up being a injector intermittantly shorting out and pulling down the whole injector drive circuit. I found it by checking the injectors with a ohm meter. I'ts been a while but i think each injector should read at least 8 ohms. and if by chance you find a bad one you can unplug it and the car should rev up past 2000 rpm's.
Old May 20, 2003 | 05:58 PM
Car: 1987 IROC Z
I will be replacing the injectors soon as well.. I will try that though.. thx. Any one else have any other ideas.?
GTAman
Jul 3, 2024 07:29 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
wisemanz28
Sep 20, 2015 01:26 PM
ULTM8Z
Sep 16, 2015 09:15 AM
challenger71
Sep 10, 2015 04:58 PM
