car still missing....
Old May 19, 2003 | 03:03 PM
19WS6T/A91's Avatar
my car is still missing i cant figure out what is going on. the timing is at 8 degrees advanced, here is what i have tried already. https://www.thirdgen.org/techbb2/sho...hreadid=178370 any ideas?
Old May 20, 2003 | 12:44 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You don't want any fresh air to be coming through the A.I.R. lines. Was it idling good for a while with it broken? Was the temperature the same as the bad idiling days? If not, then I would say that it is the source of the problem.
If all that checks out, have you scanned the car for knock, or low fuel volumes? You might have a drop in pressure, like the pump is going out. When it was running fine, was there a slight stumble from take off, or slow speeds?
Old May 20, 2003 | 01:29 PM
19WS6T/A91's Avatar
ok, i capped off the lines, that did not fix it. i checked the fuel pressure and it is consistent even while missing. i dont have a way to check for knocks and im not sure what you mean by low fuel volumes. im going to drop the tank tomorrow, i believe it is something in the tank, taking that it only happens once the fuel level reaches a certain point
thanks,
david
Old May 23, 2003 | 09:39 AM
19WS6T/A91's Avatar
anyone?
Old May 23, 2003 | 09:59 AM
91blackgta's Avatar
check out the rubber line between the pump and metal line on the sending unit. see if it is loose. check the pulsator also.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
