Can you delete all the air injection/smog crap???
Old May 24, 2003 | 09:21 AM
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
Well, my friend wants to go with some headers and a y-pipe but doesn't have the $$ for the air injection headers. Emissions are no problem around here, so we will take off the cat also no doubt. He has a 90 IROC L98, ported heads, SLP cam with juts a Dynomax catback now. Any suggestions would be great, including best headers for the $$ and etc. Thanks!
Old May 24, 2003 | 12:46 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes he can get rid of the smog (A.I.R.) crap. he still has to keep his O2 sensor though. as for headers, slp or hooker super comp shorties.
Old May 24, 2003 | 05:08 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
If you wanna go crazy, get the LT Hookers. You will need to have an O2 bung welded to it though. And you will need to reroute your accessory belt, I needed a longer belt when I eliminated the smog pump. 968K6 was my belt size...
Old May 24, 2003 | 07:32 PM
MdFormula350's Avatar
i deleted my smog pump and my air tubes, hoses, and that black box.
cars still runs good.
i am running this belt setup
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old May 24, 2003 | 07:33 PM
Attached Thumbnails Can you delete all the air injection/smog crap???-im000135.jpg
Old May 24, 2003 | 07:35 PM
Attached Thumbnails Can you delete all the air injection/smog crap???-im000136.jpg
Old Jun 3, 2003 | 09:28 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
what did you guys do to the black box wires??? I dont know where to out them!
Old Jun 3, 2003 | 01:30 PM
just taped them up to that hose.
Old Jun 3, 2003 | 02:45 PM
87t/a gta's Avatar
after u take off your smog stuff, will it cause a code to be set or for the eng to run funny ?
Old Jun 3, 2003 | 08:29 PM
bandit454's Avatar
It won't cause any codes. The ECM only sends a signal to the air pump solonoids, it doesn't get any feedback whether it worked or not so it will not cause any problems what so ever.
Old Jun 4, 2003 | 09:36 AM
TransAmTBI's Avatar
Engine: 305 TBI
what a reliefe! no code??? gm must be slipping lol
ususally i get a code if my cars is dirty
Old Jun 4, 2003 | 07:47 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im in the process of removing all my air crap too....is the thing in the middle of the fuel rail anything to do with air? I think its the EGR valve? whats that do?
thanks
Oh yeah, Im stuck! I cant get to the bolts on my stock exhaust...
DAMNIT!
LOL
Attached Thumbnails Can you delete all the air injection/smog crap???-dsc00177.jpg
Old Jun 4, 2003 | 07:57 PM
bandit454's Avatar
Yes, thats the EGR valve. You need to leave that on unless you burn a new chip or you will get an error code.
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
