HSR swap complete!
Old May 24, 2003 | 04:37 PM
BadBowtie88's Avatar
HSR swap complete!
Well, after getting the adapters for the fuel line I forgot to order , I'm finally up and running. Got her runnin yesterday. Went up to the track and the line to get in was backed up so bad, I just said screw it and came back. But, if rain stays away next weekend I'll have times to post. I really like having some upper RPM now. It takes away a little torque, but, in a good way. It allows me to mash the gas off the line and not completely destroy the tires. It hooks good. Power isn't great from about 1500-3000RPM, but, it's not designed for power below that. I can gaurantee you though, once you hit 3000, watch out! It takes off like a bat out of hell. I went from about 20mph and then punched it....absolutely raped the tires. Has lots upstairs.
Old May 24, 2003 | 05:05 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Glad to hear it!!! Doing my swap this summer...
Old May 24, 2003 | 06:39 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Congrats. How long did the swap take and did you have any problems?
You put the HSR on a basically stock L98 right?
I'd be interested to see some times.
Old May 24, 2003 | 08:08 PM
Provided you have everything you need to assemble it, should only take you 3-4 hours. This was a learning experience and it took a bit to figure out everything I needed. Actual work time though 3-4 hrs. Yes it is a stock motor. All I've done is deleted the air boxes. See sig.
Old Jun 5, 2003 | 02:39 AM
mastrdrver's Avatar
Any new times? :lala:
Old Jun 6, 2003 | 09:25 AM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Will the HSR match with a zz4 cam ?
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
