people who have swapped from MAF to SD
Old May 26, 2003 | 05:15 PM
cobrakiller1989's Avatar
other than repinning the wires into their new locations and rewiring the knock sensor and MAF sensor to MAP sensor, was there any other issues that you ran into that i would need to know. i am about to dig into this swap this upcoming weekend and want to make sure i have everything ready to go for it. also, did you use any step by step webpages to guide you along, and if so can you post it? thanks alot
Old May 26, 2003 | 10:49 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
That's pretty much all there is to it. Try this excel file for repinning.
Repinning
Old May 27, 2003 | 01:33 AM
OMINOUS_87's Avatar
Check out what Mike Davis documented, this guy covers it all in detail!
http://www.eecis.udel.edu/~davis/z28/
Old May 27, 2003 | 11:49 AM
tpi_roc's Avatar
The swap is much easier and smoother than the 870 --> 165 swap in my opinion.
Neither swaps offered any resistance, Just a simple repin and some wiring splices and you're good to go, dont sweat it, just jump in.
chazman
Aug 28, 2018 03:25 PM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
