New 406 CI miniram is installed.
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
Fresh and 200 miles into the break in!
1985 White/Red 4+3, 406-CI, 10.6:1 Static, 8.3:1 Dynamic CR, TPIS Miniram II, 215/CC-Dart Pro-1 Heads, Hooker 2151-1, Walbro-340, Flow Kooler, .225/.233 @.050 & 280/289 Bullet Custom Grind Cam, Comp Pro-Magnum 1.6RR's & Retro Roller Lifters, Taylor Spiro-Pro 8mm wires, BBK 58MM, Centerforce DF II, 870 to 165 ECM swap, Precision Balanced Drive Shaft w/Spicer greaseless Joints, 315/35-17 AFS-ZR1
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Originally posted by Formula383
Motor looks great. Lots of luck w/ it. Question to you were did you get the hose that connects from the Throttlebody to the MAF?
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Originally posted by Maroon-IROC-Z
It's a vette, you can find them on those years.
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
OK, tell me about your static and dynamic compression and how you calculated dynamic compression.
Also, why do you have decimal points before the 225 and 233 below. Isn't that your .050 duration?
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
http://www.empirenet.com/pkelley2/DynamicCR.html
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Looking good. Real good. Take that sucker to the track. I am curious as to what it runs.
gixxer92
Apr 12, 2022 12:09 AM
efiguy
Sep 27, 2015 01:30 PM
