How is it that almost every TPI setup I see has some dents in the runners? What are people doing to cause this frequent mishap?
Did you ever touch one or even look at it the wrong way? I can't figure out how people high polish them. They look ten times heavier than they really are.
I wonder if just the fact they get hot and bend would be it. After all they are fairly thin aluminum.
Dropping one, dropping a wrench on one... tightening the bolts and having the ratchet spin to hit it...etc etc
Like shaggy said, they are thin aluminum. How do you dent a soda can?
I've never seen a set of SLP runners or Accel runners in person. Are they cast aluminum, or are they just as prone to dents as the stock, TPIS, and Arizona Speed & Marine runners?
I used to own the Arizona Speed and Marine runners, but I was very careful when working around them.
Only the stock f-body runners are very thin. Even the vette style runners like came on the late 92 cars are a little thicker and don't dent easily.
I was actually lucky enough to get my IROC with mint-condition runners. The reason mine got screwed up was because I thought they were seized on when I was trying to remove them, so I tried to "unseize" them with a rubber mallet. Turned out, I didn't see the one or two screws that you have to get from underneath the plenum.
First day I ever worked on a TPI engine...
i dont think mine have any dents, but who cares they are stock ones anyway
but your right S10Wildside searhcing ebay sometimes i also found out that the runners had like a dent or two, and this one set on a tpi setup had like 7 dents just on the one
luckily no one ever worked on my car before me, so everything is mint. not for long though
Mine are still mint. I bought my car from my neighbor who never touched anything. Everything was stock and in good condition. Car only had 60k original miles
Doesn't matter, car ain't stock anymore
