Holley afpr vacuum line off
Old Jun 1, 2003 | 10:09 PM
Pappa Smurf's Avatar
Car: 91 pro street camaro
Engine: F1r procharged stroker
Transmission: turbo 400 w/gearvendor OD
Axle/Gears: moser 9" 3.89 35 spline axles
Recently installed Holley afpr w/Autometer gauge under hood. i was adjusting pressure w/vacuum line off and forgot to hook it back up-woops!! Went to local track and only ran best time of 14.57. would vacuum line off make a lot of difference? opinions please!
Old Jun 1, 2003 | 11:40 PM
bigals87z28's Avatar
Car: Check The Sig
im not 100%, and anyone can jump in and correct me, but with the vacuum line off, doesnt the pressure get affected? i think it would stay teh constant psi you set it at instead of it varying when the line is attached. You could of ran a little rich, and then evened out, but im really just taking a guess, im not sure about the fuel system.
Old Jun 2, 2003 | 12:14 AM
llvll4l2c91350's Avatar
i just installed a holley AFPR. the instructions say to adjust it with the line off. with the line on the gauge read about 43. unplugged it and it jumped to 50. thats where i left it at.
Old Jun 2, 2003 | 12:26 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I do believe you are correct, from the looks of things in my car, through trial and error, when you disconnect the vacuum line, you are setting maximum fuel pressure. So running with the line off, is something I really wouldn't recommend. You'll be running rich at idle and low speeds which from what I've read, isn't a good thing to do to you engine.
Old Jun 2, 2003 | 01:18 AM
Car: Check The Sig
cool... i really wana get a holley unit. i might get one cause im tearing apart the motor for the heads and cam im putting in, so why not take care of any fuel problems i might have, and get a afpr. hope theres some money left in the budget.
Old Jun 2, 2003 | 09:31 PM
vacuum line off
what i really meent to ask was, Would line off have slowed me down?
Old Jun 2, 2003 | 09:57 PM
jgifford's Avatar
Car: 1986 Z28
I would have to say yes, not by much of course, but as long as the engine isn't running at optimum performance all the time, there's going to be a little lag. In your case though, the only thing I would think that may have bothered it, assuming your foot hits the floor when the light turns green, is in the later gears. Even though you're still flooring it, 2nd doesn't need as much fuel as 1st, 3rd doesn't need as much as 2nd, ...etc. So I would say that there is a possibility of you getting richer in fuel mixutre further along that could be slowing you down.
I'm no expert so I could be wrong on this, I have an interior fuel pressure guage and when in 1st and foot to floor, it rockets to about 48 PSI, and during every shift, lowers a little, bit until 4th where I have 42-43 PSI.
Old Jun 2, 2003 | 10:50 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
It wouldn't slow you down much, if any.
You're at WOT when racing. With the line off, you're at no vacuum. (which is why you adjust for WOT by no line attached)
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
355tpipickup
Sep 4, 2015 05:32 PM
