Problem post #2
Old Jun 2, 2003 | 11:33 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Problem post #2
Ok, HSR is installed. Pulled the heads this winter, looked into the cylinders. Noticed somthing strange. Pistons 1 and 3 had relatively little buildup on the pistons where as the other cylinders had a lot. I am also experiencing, what I originally thought to be a tuning issue, a low rpm bounce. What I mean by bounce is that anywhere under 2000 rpm at cruise and part throttle, the car will lurch forward and backward as much as the differential gears will allow it. I notice that it is RPM related. It bounces perhaps 200 rpm forward and backward.
Is it possible that I may have plugged the wrong injectors wiring into the wrong cylinders like #3 into #1 and #1 into #3 and that would cause this problem? What would happen if I were to switch them around and try it out? Can you do serious damage by attempting this? I am of a mind to say that yes you can unless you don't beat on it.
Old Jun 2, 2003 | 11:42 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Nothing bad would happen as your system is a batch fire, meaning all the injectors fire at the same time with the same amount of fuel.
Chris
Old Jun 2, 2003 | 11:48 AM
Car: Iroc-Z
as far as I remember its not a batch fire system... maybe I better ask the guys in DIY PROM...
Old Jun 2, 2003 | 01:27 PM
Morley's Avatar
If it is TPI then it is Batch Fire.
Old Jun 2, 2003 | 02:24 PM
Car: Iroc-Z
There goes the option of a simple fix.
Old Jun 2, 2003 | 08:01 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Make sure your injectors aren't upside down though..
LOL, j/k
Old Jun 3, 2003 | 01:54 AM
Morley's Avatar
Ohm out your injectors, at least 1&3, you should see around 16 ohms or so.
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
