bolt adapters on HSR & stock heads (center bolts)
Old Jun 2, 2003 | 05:00 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Holley PN 90748 is $55.
is there an AFFORDABLE solution to this?
I've heard about wallowing out the holes.. Any pics?
Old Jun 2, 2003 | 05:24 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
holes are already wallowed out. can take some stock tubing and angel cut it to match the 72* angle. then leave flat on other side.
Old Jun 2, 2003 | 08:09 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Even with the holes enlarged the intake won't sit flush with the heads. You'll need to have the intake milled to match the same angle as the heads. You probably have a gap right now between the intake and the block large enough for you to almost see in to the lifter valley from the front.
Old Jun 2, 2003 | 08:11 PM
mrr23's Avatar
Engine: 360 HSR
danny - it's just the four center ones. because of the 72* angle of the bolt holes. 87-up iron heads. intake sits flush with heads.
Old Jun 2, 2003 | 08:18 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Oh only the center bolts? Never mind.
Sorry, I had an intake problem with the outer bolts. Turns out that the heads that I bought had been milled and I didn't know.
Old Jun 2, 2003 | 10:57 PM
BadSS's Avatar
https://www.thirdgen.org/techbb2/sho...square+beveled
This thread has a link for beveled washers
Old Jun 2, 2003 | 11:09 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
awesome, found the bolts @ mcmaster.com
need a few measurements if anyone has them:
bolt diameter, lower wedge height, upper wedge height..
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 25, 2015 12:54 AM
Elliswon
Aug 10, 2015 12:33 PM
