installing injectors
Old Jun 2, 2003 | 07:10 PM
billyhoss's Avatar
iam going to install some new injectors this weekend in my 91 z, its a 305 tpi, now is there anything special i should know aobut, to drain the pressure if i leave it over night will it be depressured by then, second, should i put some sort of lube on the o rings so they dont dry out and last of all how would i prime it before i start it up? turning the key on and off a few times will that prime them for me? thanx in advance
Old Jun 2, 2003 | 07:23 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Re: installing injectors
use a small screwdriver & a rag on the shrader valve.
use spit.
on & off a few times works.
Old Jun 2, 2003 | 07:29 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I always have the car running and pull the fuel pump fuse and it will die out in a sec. And I use vasoline for the orings
Old Jun 2, 2003 | 08:13 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You can remove the gas cap and let it sit overnight.
Old Jun 2, 2003 | 11:02 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I've never heard that one before. How does that release the fuel pressure on the line to the injectors? Wouldn't the line from the tank to the injectors still be pressurized? That seems like it would release the pressure in the tank but not the line.
Old Jun 3, 2003 | 01:28 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I was told that by another board member a few months back and it worked fine. Your FP always bleeds off and it should easily be down to 0 psi by the morning. Removing the gas cap helps if you have to disconnect the lines from the front of the manifold. If not they will leak fuel for quite some time.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
