plenum, intake and runners
Old Jun 4, 2003 | 11:57 PM
Reddragon91's Avatar
Car: 1991 RS
Engine: 87' 350 TPI
Transmission: 700
First off, I'm not sure if this needs to be in the tech forum. If it is, can one of the mods please move it.
I wanted to know if you port out the plenum, intake, and runners, if this will have any affect on my emmisions. I'm having problems as it is to get it to pass so that's why I was concerned. I just bought some new SLP runners so while I have everything apart I was thinking of porting the three. Any info/suggestions will be helpful. Thanks, reddragon91
Old Jun 5, 2003 | 04:05 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I have all three ported(even have SLP ported runners)& never had a problem passing.
BD3
Old Jun 17, 2003 | 12:22 AM
92-tpi-z's Avatar
im doing the same thing. i just ordered the slp runners but the only thing im porting are the runners and the plenum. all i have heard about porting the intake is horror stories about losing all the bottom end. is your car a 305 or 350?
Old Jun 17, 2003 | 01:10 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you do not correct your emissions difficulty, then you'll fail worse with porting. However, correcting the tune of your car, and I am assuming it is mostly stock, should be easy (a good tune up).
Old Jun 18, 2003 | 11:57 AM
Car: 1991 RS
Engine: 87' 350 TPI
Transmission: 700
92-tpi-z --- the car has a 350. It originally had a 6. I think the reason it doesn't pass is because the eletrical part of the installation is not in tip top shape.
D Stroy H8 --- the car is mostly stock. the only thing it has right now is a cam and air foil. I have zz4 heads, 24# injectors, and the SLP runners sitting in the garage that I plan to install. I am just waiting to get everything I want and install it all at once. I will be ordering an afpr from bbk in about a week so I'll have that too. The only thing left is SLP headers but that might be awhile being that I don't have the 500 bucks for them right now. Them I'll have just about everything I need.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
