which relays to make tpi run ?
Old Jun 6, 2003 | 01:49 PM
87t/a gta's Avatar
hi i am pulling a tpi set up from a 87 trans am . an i need to know which relays an an sencors i need to take from the donar that are not on the eng . an general area that there in if possable. so i didnt have to buy new ones .
thanks any info would be great
Old Jun 6, 2003 | 02:51 PM
ULTM8Z's Avatar
You'll probably want to verify what I say, but in my F.I. conversion, I only have a fuel pump relay. However, since you're pulling out of a Mass Air car, I believe you'll need the MAF relay as well. Not sure about the locations though.. my car is 1971.
Old Jun 6, 2003 | 06:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Depending on the eprom you burn, you can modify to suit your needs...but if I were you, and since you have the donor car to pull from...remove all the wiring harness'es that connect from the ECM, all the way to the engine bay.
All the relays and sensors will be there. Get everything you can, will make the eventual swap less painfull.
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
