why is this...
Old Jun 11, 2003 | 05:17 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
why is this...
scoggin dickey sells the LT1 and LT4 stock grind cams. why are they on rated to make power idle to 4500rpms, i thought the 92-97 LTx series engines made good top end power and red lined around 6k? the reason i asked was because i plan on rebuilding my 305 soon and i was happy with the results of the stock LT1 grind cam (95) and i was thinkin maybe id swap in a stock grind LT4 cam when i do the rebuild.
LT1:
LSA: 114
201/208
.447/.459
LT4:
LSA: 115
203/210
.476/.480
think i should, or would i be better off with a 2032HR cam, zz9, zz4? or just stick with what i have. ive even had crazy thoughts of putting together the 350 i have
Old Jun 12, 2003 | 10:24 AM
tpi_roc's Avatar
redline is only a function of safe RPMs before parts start to break
Redline does NOT mean the peak of your power curve
Old Jun 13, 2003 | 09:18 AM
Vader's Avatar
Comp 07-305-08 .510/.520 220°/230° 114° LSA
It produces torque well beyond 4,500 RPM in an LT1, I guaranty. It may be a little much for a TPI, however.
Old Jun 18, 2003 | 03:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
is it true that these cams are rated to 4500 only? i question this because the only cars ive heard about falling off at that rpm is the TPI inducted engines. ive never heard about an lt1 with soggy top end.
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Blue419
Sep 10, 2015 01:03 PM
Thaney9
Aug 7, 2015 08:25 PM
CD MaroMan 91
Mar 13, 2002 04:15 PM
