SLP LT1 airfoil vs. TPiS TPI airfoil
Old Jun 14, 2003 | 12:23 AM
maverick544's Avatar
Is there any diffrence between a SLP LT1 airfoil vs. TPiS TPI airfoil?
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=644
vs.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33558
I wanna get this just wanna make sure it will fit my 89 305TPI
Old Jun 14, 2003 | 01:50 AM
SHO350's Avatar
Car: 1991 Trans Am
There is no difference between a LT1 and TPI airfoil.
Don't pay $59 for the TPiS one, though.
I got mine for $29.95 here:
http://www.ecklers.com/product.asp?d...N0SM2EPTSU1ALF
Old Jun 14, 2003 | 08:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The only way to compare Airfoils are by Price. Buy the Cheapest one you can find.
Old Jun 16, 2003 | 10:12 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
they are both a waste of money. Over the weekend I saw a dyno test done on a mid 90s Impalla SS with the LT1 on Horsepower TV. Before and after results showed no difference whatsoever. Same car, same dyno same day, same hour, same conditions.
Old Jun 16, 2003 | 06:15 PM
S10Wildside's Avatar
I did see those dyno runs, too. Ran 210hp with and without the airfoil. I wouldn't buy it.
I'm sure Holley really appreciated that episode! :sillylol:
Old Jun 17, 2003 | 07:53 AM
Engine: 3.0
That was actually a good episode...I really appreciated the back to back dyno testing...most of these type of shows just talk...but this episode actually helped me make decisions on parts I was thinking of buying...
Old Jun 17, 2003 | 06:34 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
the airfoil is only supposed to decrease air turbulence going into your engine... its more of an efficiency product than performance
Old Jun 18, 2003 | 03:40 PM
rezinn's Avatar
Is that why they sell it based on increasing power? We've seen flow tests where the air foil increased flow through the throttle body, that's got to be good for something.
Old Jun 18, 2003 | 04:02 PM
eric m 91 rs's Avatar
airfoil
did you guys ever think that maybe the airfoil works better when the car is say cruising at 60, i mean on a dyno there isnt really alot of air being pushed in the cars face (yea they have a fan but thats not helping all that much) so the throttle body is just sucking in the air but when at speed it just ingests the air and i think thats when/where the airfoil does its job and reduces the turbulence and therefor increasing flow of the air going into the throttlebody. just something to think about.
Old Jun 18, 2003 | 04:03 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
Yeah it is good for horses when your going fast enough to create the turbulence into the throttle body... if your on a dyno it wont register because no air is being forced into the engine like it would be if you were on the highway unless your at SLP where they have a huge *** fan that blows air at the car simulating if the car were traveling
Old Jun 18, 2003 | 04:04 PM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
The airfoil's properties will not be seen until the worst restriction in the intake system is addressed. A lot things need to be done first, like the MAF screens and the airbox. The plenum and runners themselves are huge restrictions on 350's.
tj
Old Jun 18, 2003 | 04:17 PM
DJP87Z28's Avatar
The Airfoil and K & N air filters are in the same class, may not help much but I am USING BOTH items on my car.
Old Jun 19, 2003 | 12:49 AM
89IRO's Avatar
Got a few questions:
1) I've seen a few guys totally cut out the air boxes (the part underneath of the filters) to increse air flow. Now if I did this would I have a problem with water entering, or touching the new KNs? And to cut this out, would a dremel be good?
2) As far as the screen(s) on the maff, is there one or two of them? Is it unsafe to remove these screen(s), because I am aware of how much $ a new maff costs, and I really wouldn't want to screw it up by removing the screen(s).
So what kind of HP/Fuel eco. gains can I expect from cutting the air box, throwing in some K&Ns, removing the maff screens, and adding an air foil? Thanks. -89IRO
Old Jun 19, 2003 | 07:46 AM
DJP87Z28's Avatar
My opinion, just remove the (4) Baflles below the air filters in the air box and leave your Maf alone. No significant HP or performace gains will be made by these items. Now thr PRO & CON replies will start....
Old Jun 19, 2003 | 12:28 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
I don't know if cutting the MAF, airbox, and adding all the little things really helps out alot, but all to gether, they are probably worth a little bit. ???
Like mentioned, the rest of the intake needs to be worked as well, no point in opening a floodgate if there is a bottleneck right down stream.
Old Jun 19, 2003 | 01:01 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i cut 2 big windows in the box..and left a half inch between the holes...i want to say that i gained power but im sure it was all in my head..however, i DID infact notice an increase in throttle response, which is fine aswell for 5 mins worth of work...
the K&N was not in my head, i gained 18 hp with it AND the holes in the box..i have not installed an air foil. i have heard itll gain like 10 cfm?..but its purpose IMO, is to increase throttle response, which im sure it does..
another free mod is to grind down the egr walls right behind the throttle body in the plenum...this may seem wierd, but it sounded like it changed my idle..you know how the L98 idles nice and smooth...well my car idles a little rough because its a G92 LB9, so when i ground down the walls the idle went a litte rougher..(i dont mean rough as a bad way...it sounded really good even though it was internally stock..)...id would have to say i gained a good 10-15 Hp...it felt quite a bit crisper and it pulled a litter better on top...
also if u do plan on buying a airfoil, id suggest spending another 2 bucks or so and converting to a AFPR
that combined with the K&N, holes in the airbox, ground EGR walls, and the AFPR, id be fairly confident in sayin youd gain a peak of 40-50 hp
people have documented gains of 30+ on fuel pressure adjustment alone
Old Jun 19, 2003 | 01:49 PM
89IRO's Avatar
Well, I'll at least take a look at the maff, but I'm not sure if I'm gonna do that. As for the air boxes, do you mean you didn't cut them out completely, you just cut out a portion of them? I've already taken out the two baffles in each box that are held in with screws. I wonder if I can just use a drill to drill out some holes in it, instead of cutting it with a dremel. Airfoil- don't know about that one because I'm not getting it from jegs or summit (where I will get my KNs) becasue their's are too expensive, so either ecklers, or slp, but then that means an extra shipping charge for me, so we'll see. Thanks for the help guys. -89IRO
Old Jun 19, 2003 | 01:50 PM
89IRO's Avatar
Oh, and I'd believe a crisper throttle response, but 40-50 HP, come on man! I wish! -89IRO
Old Jun 19, 2003 | 02:27 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
40-50 HP ... if it were only THAT easy
Old Jun 19, 2003 | 03:01 PM
DJP87Z28's Avatar
4-5 Horsepower, if the wind conditions were right. Would be more like it. 40-50 Suck that big wind.
Old Jun 27, 2003 | 02:57 PM
89IRO's Avatar
I just did the coolant bypass to the TB and I was pleased with the results. I can't say I really noticed much except that now I can touch the throttle body without burning my hand (which must be good for the TB). However, I did notice quicker throttle response when I used that Valvoline synthetic TB cleaner. This stuff just dissolved all the carbon build-up in the TB, in front of and behind the blades. I'm sure any good cleaner would work, but I got this stuff free, so I used it. Oh, and it came with a big swab which made it easy to clean. My question is about the maff screen(s). I know it has two screens, but I only want to remove the one closest to the TB. It is easy to get to, but how to I remove it? It looks like it can just pop off, but I didn't want to mess with it since that is an expensive part. Will it hurt anything if I remove the screen closest to the TB? Thanks. -89IRO
Old Jun 27, 2003 | 06:14 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
I just took ripped the screens out with pliers. The wire mesh rips quite easily.
Old Jun 27, 2003 | 08:22 PM
DJP87Z28's Avatar
When you need a replacement MAF, do a search for the address for a Wells MAF.
Old Jun 27, 2003 | 11:38 PM
89IRO's Avatar
So will the screen come out all as one piece? If I get some needle-nosed plyers in on of the small holes can I just yank the thing out? Thanks. -89IRO
Old Jul 24, 2009 | 09:47 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: SLP LT1 airfoil vs. TPiS TPI airfoil
A K&N air filter will give you the same HP gain as any NEW air filter. K&N isn't anything magical.
Old Jul 24, 2009 | 10:34 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
The only benefit in my opinion of the k and ns would be that you can wash and re-use them. I think they do flow a bit better though.
Old Jul 24, 2009 | 10:50 PM
Krik's Avatar
Engine: 5.7 TPI
you are half right
Old Jul 26, 2009 | 02:27 AM
3rdgenred's Avatar
Car: 6.7 Powerstroke
Anyone have any comments on the Ram Air intake box. Im really debating about getting one of those and also a Ram Air II hood for my Form 350.
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
