fuel pressure regulator vacuum
Old Jul 26, 2009 | 07:14 PM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Hy tpi guys,
Iwas wondering if i remove the vacuum hose from the fuel pressure regulator and demple it would it dump up the pressure and help me when racing?
Old Jul 26, 2009 | 09:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pressure regulator vacuum
Then it would run rich all the time ; not only at WOT.
If you set the pressure at recommended 43psi; you will see with a gauge attached that it is down to 38ish at idle with the vac attached.The engine vac adjust the fuel pressure to give correct fueling as needed.
MustangBeater20
Oct 29, 2022 09:20 PM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
89-S-dime
Aug 12, 2015 11:57 AM
