Not rollers? wtf?
Old Jun 14, 2003 | 08:49 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Not rollers? wtf?
I thought you guys said that all engines 87 and up had roller rockers? Well I dont have roller rockers......So what gives? Not he engine hasnt been changed and yes its the original engines.
No what cam do I get? What kind of rockers are these?
thanks
close up
Old Jun 14, 2003 | 08:50 PM
airdeano's Avatar
gm doesnt use roller rockers on factory engines, they use roller
cams.
the ls1 engines use rollet trunion rockers, thats it on roller valve
trains..
airdeano
Old Jun 14, 2003 | 09:05 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
They use roller lifters (of course roller cams to go with the roller lifters).
Old Jun 14, 2003 | 09:16 PM
So do I have a roller set up or what? When I look into getting a cam, so I look at the roller cam or hydrolic cams?
OK, no roller rocker but roller lifter is what I got? HUH?
Is the lifter under the spring? Ive never removed any futher than my cover. Can some one explain whats where? Weres the seals that cause smoke at start-up?
Old Jun 14, 2003 | 10:59 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
the lifters are under the pushrods, on top of the cam lobes. They 'lift' the push rods. In order to get to the lifter's you would have to take the manifold off. 87's have a hydraulic roller cam with hydraulic roller lifters. I prolly spelt hydraulic wrong but w/e.
So when you buy a cam look for hydraulic roller ones, unless you want to change back to flat tappet lifters.
Old Jun 15, 2003 | 08:16 AM
bigals87z28's Avatar
Car: Check The Sig
roller rockers are not stock on any roller camed engine. hydr. roller cams talk about the actual cam profile a how the lifter works. Not that there are little rollers in the rockers themselves. You do have a roller block, you just need to buy a set of roller rockers. I sugest the Pro Mags from Crane... they look the strongest and will last longer then the aluminum ones.
Old Jun 15, 2003 | 09:46 AM
Vader's Avatar
Originally posted by bigals87z28
roller rockers are not stock on any roller camed engine....
Of course not in OUR cars, but the LT4 in Corvettes came with aluminum rollerized rocker arms. Too bad they were aluminum. At least the GM Powertrain guys were smart enough to demand that Crane reinforce teh weak areas of their Gold Race rockers before installing them on a Chevy engine. Even they realized their weak design traits.
BTW - Pro Magnums are from Comp Cams, not Crane. Probably the strongest stud-mounted rocker you can get is the forged stainless Comp "Hi-Tech" rocker. Pro Magnums are a close second.
Old Jun 15, 2003 | 11:05 AM
Car: Check The Sig
Ahh vader.. as soon as i got in my car after i replied i was like.... chit there comp.. not crane... hehehe... Whats teh tag on the "hi-tech" rockers? mmmmm... forged stainless steal... mmmmmm look pro mags look like ther built like a brick chit house.. and the lt4, well.... its an lt4... between fbods and vettes, there is like 100 out there hehehe
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
