Need help for swap
Old Jun 15, 2003 | 12:48 AM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Need help for swap
Hi,
I'm gonna be doing my first TPI swap. I'm swapping out my TBI for a TPI. I'm only swapping the intake to start off with. I'm gonna install the TPI on the 305 motor for now, just to get it running properly. I bought a complete Speed Density setup. It has the ECM, prom, wiring harness, sensors, 19# injectors, distrbutor, coil, throttle body, ect. It was off a 91 GTA. I'm doing this in a 92 RS. I was wondering if anybody could recommend a good book, website, ect. that details a swap. I looked at my harness and it's got battery terminals, fan relays, and being my first swap it's kinda overwhelming.........
Old Jun 15, 2003 | 10:29 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
TPIS has a tpi swappers book that should be helpful
just to make sure that your spending your money wisely on their overpriced parts call them up and make sure it goes through what you need in their book. www.TPIS.com
Old Jun 15, 2003 | 10:53 PM
JR305's Avatar
I just did the swap, I went from TBI to Holley stealth ram using a SD harness. It was my first swap as well. It's not that hard, this message board has all the info you would need.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
