MAF vs SD airflow debate
Old Jun 15, 2003 | 03:29 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
I'm doing the swap soon, and I know this is a hot topic here, but I''m only interested in the airflow aspect of this swap.
The thing is, with MAF, I have a cold air intake ducting running under my front fender. But the air has to go through several restrictive tubes and twists and turns to get to the throttlebody.
With SD, I'd have a K&N bolted directly onto the throttlebody. Now it would be getting plenty of direct air from all around the filter, but I know it's hot air from the engine compartment.
So which is better, less COLD air or MORE hot air?
Old Jun 16, 2003 | 04:30 PM
kevinc's Avatar
Car: 1982 Z28
Re: MAF vs SD airflow debate
They're both bad to varying degrees. More cold air is the way to go.
Old Jun 16, 2003 | 04:52 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Re: Re: MAF vs SD airflow debate
Thank you very much captain obvious...
Old Jun 16, 2003 | 05:24 PM
OMINOUS_87's Avatar
Well considering that most people will just ignore this thread because of your attitude I will give my .02 worth.
Since all the topics you want info on have been exhausted on prior threads you might just want to use the search feature of the site, I can say with a good deal of certainty you will find your answer, captain obvious!!!
Old Jun 16, 2003 | 05:50 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Less cold air? You have to be kidding right? As far as I have ever known the MAF is not a restriction nor is a CAI.
Might not want to have hot air pumping into your motor
Old Jun 16, 2003 | 06:19 PM
kevinc's Avatar
Car: 1982 Z28
Re: Re: Re: MAF vs SD airflow debate
I figured if you were dumb enough to even ask that question, maybe it wasn't obvious.
See ya next time you need help, and given your IQ, going into an SD swap there will be plenty of questions...people could pretty much tell you anything and you won't know the diff until you turn the key and the ECM smokes itself...
Have a nice swap, and feel free to post any questions along the way.
Old Jun 16, 2003 | 08:53 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Search topics within the last 30 days, you'll find more info. than you will ever need about SD vs. MAF.
Old Jun 17, 2003 | 03:22 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Sorry, I never meant to get insulting but everyone knows more cold air is better, but that's not even an option here...
This was never intended to be a thread about MAF vs SD debates, I've done all the searches and the reasons for me doing the swap are my own.
I was only wondering which was a more important aspect of airflow to increase horsepower; quantity or temerature...
Old Jun 17, 2003 | 03:27 PM
OMINOUS_87's Avatar
Well since you apologized for your rudeness, check out gm high tech performance they just did some 1/4 mile track testing with magnum tpi, bolting on the filter to the tb provided the poorest times.
Old Jun 18, 2003 | 02:20 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Gee, you think with a thread titled "MAF vs SD debate"? Ominous is right about the article, it's in the May 03 mag.
Old Jun 18, 2003 | 10:07 AM
OMINOUS_87's Avatar
LOL about the title!
The article is online as well, browse through the tech part of the webpage at GMHTP.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
racereese
Oct 3, 2015 03:46 PM
